Toda Pistons and FRM cylinder walls
Old 10-23-2004, 06:25 PM
Slows2k's Avatar
Sorry I'm not more help. Maybe someone else will chime in here.
Old 10-23-2004, 06:26 PM
ArinX's Avatar
I will probably end up resleeving, just to be on safeside and so i can run any piston i want to acheive the compression i want.
thanks again
Old 10-25-2004, 09:01 PM
chris_barry's Avatar
Does Toda specify a recommended bore clearance? The differences in materials, design and heat profiles mean that different pistons will expand by different amounts and often into different shapes. I've seen pistons pickup on cast iron liners with similar damage to those pictured where insufficient bore clearances were used.
I normally use 3-4 thou bore clearance in race motors with forged pistons (81mm bore). If you use the factory clearances of 1 thou the pistons will pickup on the bores in no time at all.
Chris.
Old 10-25-2004, 09:11 PM
honda9krpm's Avatar
A member in Australia is running a set of Jun pistons with 17psi in the stock shortblock without any problem. He's looking at changing them to Toda soon. I don't know for sure whether the Toda pistons will have problem or not but if Toda say so then it's unlikely given that the Jun pitsons are ok.
Old 10-26-2004, 12:33 PM
ArinX's Avatar
Chris.
usually the piston manufacturer recommends the clearance. I definitely would not go with oem spec on this one.
Thanks for your input guys
L8BRAKN
10-08-2017 10:59 AM
derko_06
02-11-2009 07:13 PM
lowandsmooth
10-07-2008 02:22 PM
spinmasterext
12-23-2005 02:08 PM
Team Hybrid
11-04-2002 02:15 AM
Quick Reply: Toda Pistons and FRM cylinder walls
