Tips for Valve Cover Removal
I just received a Spoon valve cover and was wondering if you guys could tell me how to remove PCV hoses. I tried to remove them this weekend, but I could not get them to budge!
Thanks,
Will
Thanks,
Will
Originally Posted by jzz30,Jan 29 2007, 08:01 AM
just pull the valve out!
Thanks. The front hose does not have anywhere to unscrew. Do I just have to use a lot of force to pull the hose off? I helms manual just says something like "remove the hoses."
You can use a screwdriver and pry at the ends to see if it'll let go, I wouldn't go pulling on hoses cuz you can do more damage to it. Also by pulling, you'll stretch the shit outta the hose which wouldn't be wise.
The first time you need to take them off they will be a PITA.. I use pliers & a screw driver w/ electrical tape wrapped on the end to prevent scratching.. pull & pry until you're blue in the face
Boostaholic
06-17-2007 01:31 AM
