Timing Chain Tensioner Noise
Old 09-06-2015, 04:04 PM
  #861
Slowcrash_101's Avatar
Sand blasting the worm gear is useless.
Old 09-06-2015, 04:15 PM
  #862
RWDlover's Avatar
Originally Posted by Chuck S
Remember? It's called preventive maintenance. Replace parts known to go bad before they go bad.
-- Chuck
You just replaced a part thay may never need to be replaced, or might be good for another 100k miles, and doesn't cause any other damage when it fails, as long as you replace it on time. It's like replacing your brakes before their service limit, this isn't preventative maintenance, it' false economy.
Old 09-06-2015, 07:08 PM
  #863
When the TCT fails the chain can jump and change timing then it's bye bye engine.
Old 09-07-2015, 06:47 AM
  #864
Chuck S's Avatar
Received 1,235 Likes on 1,079 Posts
Aren't you the guy with multiple TCT problems? Replaced with an OEM version?
-- Chuck
Old 09-07-2015, 08:14 AM
  #865
RWDlover's Avatar
-- Chuck
I guess you are confusing me with someone else, i bought mine a few months back and had the TCT noise since day 1, it stopped for a while after the first oil change but returned after 1000 miles, so i replaced it with the a new OEM one and problem is gone. When you replace the TCT and the noise comes back shortly, the problem most probably is not the TCT itself but other, more important things. Chain strech, or even worse, low oil pressure, can be a few. I am against using aftermarket engine parts if there isn't a reason, for example stiffer TCT needed because of the use of aftermarket camshafts and/or stiffer valve springs.
Old 09-07-2015, 08:17 AM
  #866
RWDlover's Avatar
This is something i've never heard off happening. Technically, maybe it can happen, but the tensioner has to totally let go/fail to allow the chain so much slack to jump a tooth. If TCT noise appears, there's plenty of time before such a failure can become a possible scenario. Afterall, if you've TCT noise it's not wise to rev it to 9000 before it's being fixed.
Old 09-07-2015, 08:32 AM
  #867
Not at first, no you're absolutely correct. However once the problem begins to manifest itself, it won't get better only worse unless corrective steps are taken.
Old 01-23-2016, 01:51 PM
  #868
morpheus151515's Avatar
Hi, before I spend money on a TCT would anybody be able to tell me if this noise is the TCT, or something else? Engine is warm in the video. http://youtu.be/YHp-J9wWvIc
Cheers,
Mark
Old 01-23-2016, 02:41 PM
  #869
steelers743's Avatar
Cheers,
Mark
Video is private.
Old 01-24-2016, 01:04 AM
  #870
Sorry! Public now
Quick Reply: Timing Chain Tensioner Noise
