Timing Chain Tensioner Noise
Old 10-22-2008, 10:07 AM
  #611
2poor2mod's Avatar
Mod Used TCT or New TCT: Used TCT
Mileage put on since Mod: 400
Type of Mod(sandpaper or sandblast): Sandblast
Still Working (Yes or No): yes
Oil used: Still currently using Mobil 1
Old 11-20-2008, 02:57 PM
  #612
wisdom's Avatar
After reading through 25 pages, do you have an update Billman on your TCT mod?
2poor2mod, Im assuming that if you get the worm gear sandblasted, it will fix the tct noise?
Thats better than spending $130 some dollars on a new TCT.
Old 11-20-2008, 03:34 PM
  #613
Billman250's Avatar
Received 1,398 Likes on 837 Posts
TCT parts left to right:
TCT housing
large diam. spring
worm gear (sandblast the entire outside of this piece)
small diam. spring
pin
piston
Old 11-20-2008, 04:41 PM
  #614
black2000's Avatar
Well, my car just hit 130k... I'm changing out the original for a new TCT. That seems like the best idea at my mileage even though this sandblast mod. sounds very cool.
Old 11-21-2008, 09:06 AM
  #615
wisdom's Avatar
What kind of engine oil are you using?
Old 11-21-2008, 12:05 PM
  #616
krnmike's Avatar
I changed my TCT 100 miles ago.
at first the engine purred
then later the diesel sounding engine came back after a hundred miles.
Old 11-21-2008, 04:39 PM
  #617
wisdom's Avatar
Hmm... Im in the same boat as yours. The noise is faint at idle but around 2.5~3.5 its pretty loud. I don't know whats going on.
Are you still driving it? Notice anything awkward?
Old 11-22-2008, 11:55 AM
  #618
black2000's Avatar
valvoline 1040 full synth mostly but there has been mobil 1 full synth 1040 a few times too
Old 11-23-2008, 10:14 AM
  #619
skeithr's Avatar
i changed mine myself, very little mechanical experience just followed the diy on this site. easy as could be, 4,000 miles later still runnin smooth
Old 11-24-2008, 08:01 AM
  #620
devilchrist's Avatar
I had the noise also. found my Engine oil was almost a quart low.. filled it up to middle of the mark and noise is gone..
perhaps the tendancy of AP1 motor's to burn oil has something to do with the TCT going out so often?
Quick Reply: Timing Chain Tensioner Noise
