Timing Chain Tensioner Noise
I have a new tensioner on the way, but I was wondering what would happen if we were to leave the noisy tensioners in. It is causing any damage or is just leaking down when at rest and does it have full holding power when the motor is running.
Well....one of my customers let this little item slide, now his motor has self destructed
Do it.
2002S2K.....I can do it no prob...you run the camera PM me and we'll set a day.
I have them in stock, cheaper than you will pay for sure.
Do it.
Going to do the timing chain autotensioner this weekend. The honda manual says to torque the two autotensioner bolts to 8.7 ft lbs. I could not find a torque spec for the maintenance bolt-is there one? Any opinions to which torque wrench is better clicker vs dial. One last thing-is it a good idea to coat the o-rings with oil before installing the autotensioner?
Thanks
Thanks
https://www.s2ki.com/forums/index.php?showtopic=321501
Do you guys think I have a noice autotensioner belt, or is it my lost oil cap?
Is there any way to inspect the autotensioner belt to see if indeed it does need replacing?
In my car, when i throttle there's no noise but when i take my feet off and the rpm starts to fall there's this annoying noise which sometimes sounds worst and sometimes not so bad. What do you think?
Tensioner,
Just had mine replaced last week under warranty.
Over time it gets worse and worse, and if the tensioner snaps, you risk damaging the AC, Alternator and basically the engine.
For those of you doing it yourself, keep us posted on how hard of a job is it?
Originally Posted by pikkashoe,Sep 16 2005, 01:50 AM
Tensioner,
You are talking about the serpintine belt tensioner for the BELT.
If your oil cap fell behind the engine, and you can't find it, then that's your noise. It's common.
