Timing Chain Tensioner Install
So, replacing the time chain tensioner is pretty easy on a stock s2k. All you really need is a 10 mm socket, 5mm socket, and medium sized flat head screw driver. BTW, when you get the new one there is a pin holding down a cylinder. Its spring loaded, and the spring is very strong. Don't pull the pin until you follow a couple of steps.
You may want to remove the stock air box for easier access.
**I take no responsibility for the accuraccy of these instructions. USE AT OWN RISK
. But seriously, use a helm manual, know a mechanic, be mechanically inclined, whatever! But I'm writing this from memory so realize this is only a general guide to help out a little and get you started**
**If you don't have a comptech SC, I'm told there is a service port on the front of the block that you can use to pull the pin once its installed, so you should be able to jump down to instruction 5, with the last step to use the service port to remove the pin**
1. Take the back plate off the new tensioner, 10mm socket should fit nicely.
2. Use the flat head to remove the little screw underneath.
3. Use the 5mm socket to back out another bolt under that, take it completely out.
4. DON'T LOOSE ANYTHING![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
5. Make sure the car is cool.
6. Pretty sure two 10mm bolts holding the timing chaing tensioner in place, remove them.
7. Remove the old tensioner. The O-rings are pretty tight, so it may take some effort.
8. After you remove the old tensioner, grab the new one. Point it in a safe direction, put your hand over the area with the pin (don't want anything to fall out!) and pull the pin.
9. After you pull the pin insert the new tensioner. Bolt the tensioner back on. (I don't remember the torque I used, hopefully someone can enlighten us).
10. Reinstall the 5mm bolt you removed earlier, don't over tighten and don't strip it. Snug is good.
11. Reinstall the flat screw, Snug don't kill.
12. Reinstall the back plate to keep it all together. Here you may want to use some lock tight, though I'd only use medium strength myself. Opinions may vary.
One thing to remember is your dealing with aluminum. You crank it to tight and you are going to strip it out.
Now, if you have a comptech SC... god help ya. The SC oil feed is in the way, and the bracket for holding the blower is in the way, and the comptech air box is in the way... Basically, the whole damn kit is in the way.
So, what do you do if you have this kit? Go from the bottom! I recommend doing at the same time as an oil change since your going to want to remove the oil filter anyway. Basically, the tensioner is right above the oil filter, right below the oil feed for the blower. Removing the filter will give you room to get up there. Its STILL a tight fit and I'd recommend a lift... or you'll regret it.
Then you just follow the intructions above.
On hardtopguys website where the sell the tensioner they have a diagram showing where the tensioner is located, but no install instructions. So hopefully this helps somone.
Actually, I'm hoping someone will take what I put, clean it up and fill in the blanks. Or they can PM me and I'll add/correct the instructions.
Later.
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
Later.
Originally Posted by sahtt,Dec 18 2005, 02:41 PM
You don't need to replace the timing chain itself, at least not in this scenario. He is just replacing the tensioner which keeps the chain doing its job correctly.
The timing chain is supposed to be good for the life of the engine. If for some reason you need it replaced, you got bigger problems than the chain itself.
Originally Posted by 530s2k,Dec 18 2005, 04:40 PM
I may be mistaken, but I'm pretty sure you bolt the new tensioner in, then pull the pin out through the maintence hole. Otherwise it's not going to set proper tension.
I'm looking through the Genuine Honda S2000 2000-2003 manual and on page 6-48 it clearly shows how to properly remove and install the auto-tensioner. In short, you retract the plunger on the old unit before removing it, then install the new one with the pin intact. There's a service plug on the front of the block facing the airbox (you cant miss it, it lines right up with the auto-tensioner) that you remove to pull the pin.
I'm sure your method works too stitos2k, I just wanted to clarify what the manual says which the guys above were referencing.
![eek3.gif](https://www.s2ki.com/forums/images/smilies/eek3.gif)
Silver_Bullet_S
09-24-2018 07:24 AM
s2k_bmich510
12-11-2007 09:32 PM
