Timing chain tensioner
Old 03-23-2012, 08:45 PM
Aznap1ryda's Avatar
Default Timing chain tensioner
I'm about to replace the timing chain tensioner for the third time in a little less than 1 1/2 weeks. The last 2 were used with about 30-50,000 miles on them. I am going top buy a new, tomorrow from honda and I currently run 15/50 mobil 1 synthetic with a k&n oil filter. If this fails a 4th time I don't know what to do. Motor it's stock except for AEM v2 intake and a stage 2 comp clutch. Any advice would be greatly appreciated.
2000 ap1 61,500miles
Old 03-23-2012, 08:55 PM
team510's Avatar
i heard mobil 1 is bad for the tct
Old 03-23-2012, 09:06 PM
AP2 S2K's Avatar
Had to replace mine at around 55k miles and was using Mobil 1 at the time
Old 03-23-2012, 09:15 PM
s2kmiami69's Avatar
where is your proof that mobil 1 is the culprit?
Old 03-23-2012, 09:24 PM
4bang6's Avatar
click here for problems solved
Old 03-23-2012, 10:24 PM
MBHs2k's Avatar
Dont buy an OEM it's bound to go bad again. Buy one from Billman. It has a lifetime warranty
Old 03-24-2012, 05:10 AM
Aznap1ryda's Avatar
Dang I didnt even think about inlineline pro. Well now my issue is I already bought one from honda but have not.put it in in so I guess ill try to return it and get an inlinepro one. Thanks
Old 03-24-2012, 05:13 AM
USAF_S2K's Avatar
15/50 Good Lawwwd
Old 03-24-2012, 09:32 AM
rob-2's Avatar
Why are you running a 15/50? Are you tracking this car and running boost?
Maybe the issue you're having isn't the TCT.
Old 03-24-2012, 04:41 PM
s2kmiami69's Avatar
didn't even catch that. using the wrong weight oil and yet its still mobil 1's fault
Quick Reply: Timing chain tensioner
