timing chain tensioner
Old 05-05-2007, 12:58 PM
tylorweaver's Avatar
like I have the same problem with my MY05, I have almost 50k miles (FINALLY), and I get my oil changed every 2000-2500 miles, last time I heard the ticking, it was right before an oil change.. and I changed it, and it was all gone... except, I have noticed that right when it starts clicking/ticking again, i'm about a good quart of oil short in my block. After like 1500miles??? is that regular?? hahaha.. dayum. like I know I VTEC often and all, but I don't leak oil anywhere. I put in 5quarts each time i change my oil... lmao..
this ticking for me occurs right before my oil changes, like more recently in the past month or two.. and only ticks when i start it up, cold or warm... and around the 1500-2200rpm range.
TCT????? btw, it sounds like its coming back from the far end of the head, nearest towards the firewall.. is that where our TCT is located?? or can it just be the harmonic vibration, making it sound like its coming from back there??
you guys help me! haha
thx,
Tylor
Old 05-05-2007, 03:00 PM
jyeung528's Avatar
tylor...
check your engine oil every week.
you seem to always run low on oil
Old 05-05-2007, 03:43 PM
f23power's Avatar
tylor...AP2s have lower oil consumption than AP1s. i would double check for leaks and what not. the TCT is located on the lower left corner of the head(if you were looking at the engine head on with the hood up)
-a
Old 05-05-2007, 08:07 PM
XZLR8N's Avatar
I think that is what needs to be done to mine. I thought I needed a valve adjust ment, but i did it last night and the noise was still there. Me and my uncle used his stethescope to here where the noise was coming from and it is a ticking come from the head. I'm looking into getting it fixed next week now that I think I know what it is. I should probably just go ask Honda.
Old 05-06-2007, 11:14 AM
jimi's Avatar
Originally Posted by f23power,May 4 2007, 12:38 AM
a temporary fix is an oil change..but ive replaced 2 on my car already. the conclusion ive come up with is that since the TCT is oil pressure assisted, as the oil gets older it gets thinner therefore not creating the density and pressure thats ideal for the TCT to retract all the way back in. also..do you run Mobil 1? a lot of threads involving bad TCTs seemed to have revolved around Mobil 1. I switched to Royal Purple..and the noise went away.
-a
Your'e all over it Man! that's excatcly my cure. Somone should do a poll Mobil1 or synth vs Dino and failed TCT's. I recall using Mobil1 when it first came out in my van & my oil prussure gauge didn't move. After a week I drained it, went to dino and pressure was normal. I had forgotten why I stoped using Synth. Now I'm @ 100K and switched to Castrol GTX high milage. I have no burn off so far no need to top off. With M1 I would burn 1QT @3000k And my motor is quiet. The oil is still gold. M1 would be black and thin in a week So far,So good
Here's My orig. thread.
https://www.s2ki.com/forums/index.php?showt...&#entry10324497
toniotran
04-12-2024 08:38 PM
Gotpepsi
08-22-2015 08:36 PM
Ryan4601
11-30-2008 07:08 PM
Ahnold
09-02-2007 10:09 PM
DrDre1443
04-13-2006 11:02 AM
Quick Reply: timing chain tensioner
