Timing chain off? help!
Old 03-06-2015, 08:52 AM
S2k_razy's Avatar
Default Timing chain off? help!
Working on my s2k atm and can't seem to get my engine to start and run. the engine would crank but die right after start up. there's also a bit of a bogging sound when it dies out.
Could this be my timing chain?
What are symptoms if your timing is off?
should this happen if your timing chain is off a tooth or two??
HELP PLEASE!
Old 03-06-2015, 11:33 AM
Redline S2K's Avatar
A tooth off it would still run by badly. Do you have all your vacuum, egr etc hoses connect. What you're describing sounds like a massive vacuum leak.
Old 03-06-2015, 03:07 PM
Bliss's Avatar
I am pretty sure one tooth off =no start with OEM ecu. I had this happen and I was one tooth off. Fixed it started right up.
Old 03-07-2015, 06:17 AM
Pinky's Avatar
Easy question. Have you just replaced the timing chain? If not then no it's not off by 1 tooth.
You need to make sure the cam gears and timing sprocket line up perfectly.
Old 03-07-2015, 07:49 AM
S2k_razy's Avatar
Can anyone tell me how to aligned s2000 timing chains?
I need to verify where all markings should be. Pics would help a lot.
Old 03-07-2015, 07:55 AM
S2k_razy's Avatar
I had to readjust the tct.
The cam gears and timing sprocket do line up but on the opposite side of each other when I turn the crank shaft pulley to its mark.
Old 03-07-2015, 04:11 PM
99SH's Avatar
From Ballade's post https://www.s2ki.com/s2000/topic/108...ng-chain-gear/
Old 03-08-2015, 06:41 AM
Slowcrash_101's Avatar
To add to the post, if the crank doesn't line up with the cam gears you'll have to remove the cams. If the gear that the timing chain rides on is off, you'll have to pull the TCT and adjust it.
Cam gears cam wheel and block should all be aligned.
You're looking for a yellow notch on the crank pulley.
Old 03-08-2015, 06:47 AM
Pinky's Avatar
TDC: If it doesn't look like this.......it's wrong.
Old 03-08-2015, 07:08 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
I've merged your topics together.
turn the crank one revolution, recheck marks.
Quick Reply: Timing chain off? help!
