Timing Chain Auto Tensioner - Help?
Originally Posted by billman250,May 17 2005, 10:24 PM
Rattle pretty much describes it Usually right after startup. It will make a clattering noise for a sec or two then stop...in bad cases it will do it all the time at idle.
For the cost, and ease of install, just do it. It's been way to common lately.
The rattling on mine comes back very fast tho... couple of weeks at most. Anyone know what causes them to fail so easily? Its not thaty expensive but if i have to change 1 every month!
Thanks all!
ian
Thanks all!
ian
The plug you remove to take the pin out should be reinstalled with blue Lock-tight and minimal torque (aluminum housing). The factory installs it with what looks like a drop of red Lock-tight.
