Time for a Ring Job - Lessons Learned?
Old 08-23-2012, 04:02 AM
DeeKay's Avatar
Originally Posted by Muggus
I wouldnt build the motor unless your planning on boosting it. If its just the rings i would just yank the head, hone the walls, and throw new rings on. This way it will only take a short time and you wont have to take the whole powertrain out of the car. Also it will only cost you whatever the rings are and some gaskets.
Pulling the head is 80% of the job however you still need to pull the oil pan or else you wont get the pistons out without taking the rods off the crank.
Old 08-23-2012, 07:01 AM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
If you are anywhere near Smryna TN I can give you the name and contact info of a guy who does top notch work at very reasonable rates.
Old 08-23-2012, 07:33 AM
Muggus's Avatar
Yeah i know but its still easier then removing the whole motor.
Old 08-23-2012, 04:52 PM
sse2k's Avatar
Slightly OT but is that a USC frame I see on there?
Fight On brotha!
Old 08-23-2012, 06:50 PM
RedY2KS2k's Avatar
Originally Posted by jib2222
I dont have all the tools nor the experience I feel I need to rebuild an engine like this. If it was a truck I would have no problem.
Why did you throw that option into the discussion if you knew you didn't have what it takes?
Old 08-23-2012, 07:01 PM
starchland's Avatar
so with new rings you need to hone the block? that is what scares me dealing with frm lining...
Old 08-24-2012, 03:04 AM
miguel329's Avatar
New rings id hone block and take head to machine shop make sure the mating surface is square.
Old 08-24-2012, 05:22 AM
TonysMI4's Avatar
[quote name='miguel329' timestamp='1345806271' post='21960995']
[/quote
What He Said ^
You WILL have to have it honed before putting in new rings. The rings wont seat if its not. You will also need to have the head decked. So YOU WILL have to pull the whole motor out.
Old 08-24-2012, 08:26 AM
jib2222's Avatar
Fight On brotha!
It is, Fight On. Get excited for some FOOTBALL!
Old 08-24-2012, 08:27 AM
jib2222's Avatar
A revelation
Quick Reply: Time for a Ring Job - Lessons Learned?
