Time for a Ring Job - Lessons Learned?
Its time for a ring job. I have lots of smoke and my oil runs low every 1k mi.
I'm exploring some options and I'm curious to hear some feedback
1.) Do it myself
2.) Have Honda do it ($1500)
3.) Have an independent shop do it
4.) Go crazy and do a full engine rebuild
Suggestions from someone who has been there and done that would be great.
I had a buddy of mine do mine for me, we put new rings in a 60k mile block. I've only got 300 miles on the new setup, but it feels strong, and I haven't used a drop of oil yet. I haven't done a compression test though. He also did his own motor a few months ago and his car has been running really well, excellent compression, no oil burning, and clean running oil since the change.
Choose someone that really knows these motors, there are lots of critical torque values on many parts of the motor, you want to get it right. You also have to make sure the engine is worth rebuilding once you get it apart, so they need to know what to look for. $1,500 from Honda doesn't sound like a bad deal if they do it right.
Do it yourself, if you have the mechanical know-how. If you do your research, you can always find a good mechanic, possibly even ones specific to manufacture. Although the safety-net answer will always be the dealer, of course at a premium price.
I've never done them on my Ap1, however I have ringed a few vehicles. Clean the groves thoroughly, break an old ring in half and use that to get in here or if you have the funds just replace the internals (no cleaning). Done properly, will require engine assembly lube, gasket set, grey sealer, tools, and information.
What you need to do is run a compression or leak-down test (both preferably). Regardless a full engine rebuild done properly should improve conditions although it may not be physically experienced.
Oh I lost several bearings on my original motor. I bought a used motor wih 60k on it, and freshened it up with new rings and bearings and seals. We cleaned all of the pistons like Deekay mentioned, that is important while they are out of the motor, to get them nice and clean for the new rings.
What did you do with your motor?
I wouldnt build the motor unless your planning on boosting it. If its just the rings i would just yank the head, hone the walls, and throw new rings on. This way it will only take a short time and you wont have to take the whole powertrain out of the car. Also it will only cost you whatever the rings are and some gaskets.
