Time to get my Password:JDM Intake to fit right--
Old 05-07-2009, 06:03 AM
kenta's Avatar
I'd be interested to know Password's response to this ill fitment. Quite a few people including myself are having issues.
Old 05-07-2009, 07:39 AM
Stratocaster's Avatar
starbai
Remove the rad supports and tell me how it fits? You have them installed under and not over. That will cause the whole assembly to sit about 1/2 higher.
If that works, just cut the ears off the rad supports. that will allow them toi be installed on top of the CF instead of below.
Old 05-09-2009, 11:40 AM
negcamber's Avatar
Starbai...I got to get a pretty good look at a Password JDM intake installed on an MY06. He had similar fitment issues...a bit of rubbing on the hood. He suggests adjusting the hood latch up so the hood gives a bit more clearance.
Old 05-09-2009, 03:20 PM
Former Sponsor
Shadow_S2K's Avatar
Didn't the OP say he already adjusted the hood latch?
Old 05-09-2009, 07:59 PM
[QUOTE=negcamber,May 9 2009, 02:40 PM]Starbai...I got to get a pretty good look at a Password JDM intake installed on an MY06.
Old 05-09-2009, 08:57 PM
jdmgpw04's Avatar
ok
1. adjust the hood latch..
2. the sounds you hear is coming from the bar on top of this picture shown. (you can put a rubber seal to kill the brappppppppp sound your hearing.
3. before installing the intake put a soft rubber here or foam (circled) the foam must not be any thicker than a ruler. you can get it at any auto parts store. just get a flat rubber foam. maybe a seal type. (dont worry it wont melt)
4. push the intake down before you tighten the screws
5. just a little adjustment from the hood latch will make it fit.
Old 05-09-2009, 11:00 PM
Former Sponsor
Shadow_S2K's Avatar
The OP already said he has adjust the hood latch....
Old 05-09-2009, 11:05 PM
jdmgpw04's Avatar
he is just not installing it correctly
Old 05-09-2009, 11:15 PM
Former Sponsor
Shadow_S2K's Avatar
Yes that could be true, but so far no one has told him anything other than adjust the hood latch...and this must be a common problem (installation or product wise) if more then one person is having trouble installing this particular intake.
Old 05-09-2009, 11:32 PM
jdmgpw04's Avatar
yes i just did on step 4.
its not that hard to install the intake. a little adjustment on the intake will do.
you have to adjust the intake and the latch at the same time.
its a little difficult to explain but thats how close i can explain.
Quick Reply: Time to get my Password:JDM Intake to fit right--
