Time for clutch install....
Hey guys,
I've got my clutch, pressure plate, and flywheel. What else do I need? I know I'll need a couple bearings of some sort, just haven't done a clutch on my own yet. Also, could someone link me to the DIY w/supercharger? I can't seem to find it with this new search function, the old one worked much better IMHO.
Thanks,
Nate
Thanks,
Nate
Will I need a pilot bearing as well? Is there anything else I should take care of while I've got the thing out? I'd like to do as much as I can since I'm going through the trouble.
Thanks again for the help!
Nate
Nate
Pilot and throwout bearing. Not much else you can do while the trannys out besides change the transmission fluid, and grease the clutch release fork so it wont squeak. Good luck, your going to need it
I've got 82k on mine and it's still going strong. I think she is probably getting pretty close to changing time.
Answer to your question though is it really depends on the driver.
