tighting the axle/wheel hub
Old 05-03-2008 | 01:38 PM
SimbaDogg's Avatar
Default tighting the axle/wheel hub
i was looking at the TSBs for the clicking/"grunting" rear end, and i saw that tightening the axle/wheel hub from 181 lb ft to 220 lb ft was included in that. My question is, as far as doing that, can i simply just re tighten the nut, or do i have to remove it, grease it, then tighten again?
Old 05-03-2008 | 02:48 PM
daktruckie99's Avatar
You should remove, grease, then re-torque. That is how Billman did mine and a thousand other S2000s and never had a problem.
Old 05-03-2008 | 03:12 PM
SimbaDogg's Avatar
is there any trick to it? because i think a friend of mine screwed up the bearings on his crx back in the day by removing the axle nut. I tried looking through the 00-03 service manual but i didn't find anything that gave me a step by step as far as the procedure. I just dont wanna get started then do more harm than good
Old 05-03-2008 | 03:24 PM
Not sure, it looks to me like Bill just removed it, greased it, then retorqued and marked the position of the nut.
I'd wait for someone else to chime in.
Old 05-03-2008 | 03:25 PM
SimbaDogg's Avatar
thanx for the input, i'll be patiently waiting as well...
Old 05-03-2008 | 05:19 PM
Olegator's Avatar
It's straightforward, as said above, remove, re grease (just oil I believe), re torque.
Old 05-03-2008 | 05:59 PM
SimbaDogg's Avatar
ok...anyone happen to know what kinda of grease/oil to use?
Old 05-04-2008 | 08:03 PM
Olegator's Avatar
just use engine oil
Old 05-04-2008 | 08:58 PM
Antonov's Avatar
Did he put the car in the air first? Either that, or they were already done and he didn't know it.
Old 05-04-2008 | 09:15 PM
SimbaDogg's Avatar
i dont even remmeber, i doubt he will either...it was like 5-6 years ago. would it make a difference if the tire was off or if he just took off the center cap?
Quick Reply: tighting the axle/wheel hub
