Tighten Lugs While Car is Not Up On Stands
The wheels are centered by the hub. Any force exerted by the car being on the ground is transmitted to the hub, not the lugs. As long as you snug them up to center the lugs in the holes, there is no reason not to tighten them while on the ground. (Disclaimer...this assumes OEM wheels or aftermarkets with the correct center bore.)
Originally Posted by ROTFLMAO,Nov 3 2008, 01:09 AM
how much tightening do I put on the lugs before lowering? Just tighten by hand?
All of this is moot if you use an electric or pneumatic air wrench to remove and install the lug nuts . That said, I always set the lug nut final torque with a click-type torque wrench when the wheels are on the ground.
Ask me how I know
Originally Posted by Neutered Sputniks,Nov 3 2008, 03:49 PM
Yeah, hope you don't have to change a tire on the side of the road if you used a pneumatic wrench to tighten the lugs while the car was in the air.
Ask me how I know
Ask me how I know
Ask me how I know
Ask me how I know
I had to change a flat tire on the wife's A3 in a convenience store lot a couple of years ago. I was breaking the lugs loose when some twit stopped by and advised that I shouldn't loosen them until I had it jacked up.
