tighten lug nuts?
Old 02-03-2004, 01:32 PM
samjabori's Avatar
Default tighten lug nuts?
what do you use to tighten lug nuts on your rims? anybody uses torque wrench? i have one from owning a bike in the past, not sure if it is the right tool. thanks.
Old 02-03-2004, 02:42 PM
xviper's Avatar
ALWAYS use a torque wrench to tighten lug nuts. ALWAYS insist that a tire shop or mechanic shop use a torque wrench to tighten lug nuts.
The S2000 requires 80 ft/lbs on the lugs. I use 90 ft/lbs but I cannot promote this to anyone else.
Old 02-03-2004, 03:31 PM
Voodoo_S2K's Avatar
As the man said above, ALWAYS...ALWAYS use a torque wrench when tightening your lug nuts. I also use 90 ft/lbs.
Old 02-03-2004, 06:50 PM
alexf20c's Avatar
I use an Ingersoll Rand impact gun.
Old 02-03-2004, 07:48 PM
hyperpm's Avatar
90 ft/lbs here too.
Old 02-04-2004, 12:14 AM
Hyper-X's Avatar
I use 80 pounds using my torque wrench. I don't believe in over torquing, however I do make sure to re-torque the bolts after a few hard runs during autocross.
Old 02-06-2004, 10:32 AM
glagola1's Avatar
There's nothing worse (almost) than having the threads stripped off your studs by a careless shop. It's happened to me twice with past hondas and now I carry a torque wrench to the shop when I get tires mounted.
Old 02-06-2004, 11:18 AM
Former Sponsor
Gernby's Avatar
[QUOTE]Originally posted by glagola1
Old 04-07-2004, 07:55 AM
svatne's Avatar
When you get a 19mm socket, get the
"six point" style for a better fit and distribution of forces on the lug nuts. The multipoint (must common) style has a higher potential to strip
Old 04-07-2004, 07:59 AM
Former Sponsor
Gernby's Avatar
It would be pretty hard to strip a lug nut that is properly torqued.
Quick Reply: tighten lug nuts?
