Ticking idle
Old 01-24-2010, 11:27 AM
ans2k's Avatar
Does anyone else had more ideas?
Old 01-24-2010, 07:19 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Well the simplest thing would be the valve clearances being too large on one or more valves, that is usually the culprit on a mechanically sound motor. And they are typically only noisy at idle as the noise goes away or gets drowned out at higher engine speeds.
You should confirm that the head gaskets are interchangeable, I don't know if they are or if they aren't but a small change in geometry could affect the timing chain. Just a WAG here.
If you find that everything is up to spec. and you are comfortable that nothing is mechanically wrong you can mask the noise by running a good 5w-40 oil, it should disappear immediately. Amsoil 5w-40 works wonders on my engine, made it quite and smooth as silk, doesn't even sound like a Honda (all Hondas have some ticking at idle) anymore. Cheap and easy experiment.
Old 01-25-2010, 12:32 AM
Fierc3's Avatar
Check that timing chain..
Old 02-19-2010, 11:25 PM
ans2k's Avatar
it was due to a broken timing chain guide
Old 02-24-2010, 07:37 PM
Fierc3's Avatar
can you post some pics of what the broken guide looked like?? please and thank you m8
Old 02-24-2010, 08:18 PM
ans2k's Avatar
hum. sorry man. i chucked that piece out. it was also caused by a washer being not centered on the cam sprocket. what broke was the tip of guide that was the metal piece holding the plastic piece.
ans2k's Avatar
i'll try to look for it
R3AL-STATUS
03-16-2014 03:25 PM
dtmcnamara
09-09-2009 02:59 AM
spazbaboon
10-07-2008 08:57 PM
JAPCAB
09-13-2007 08:05 PM
zenkai_ate_you
04-07-2006 04:57 AM
Quick Reply: Ticking idle
