Ticking idle
Old 01-21-2010, 03:42 PM
ans2k's Avatar
Default Ticking idle
i recently replaced my valves b/c they were bent. and i went ahead and replaced all the valves and one retainer. and i got a new head gasket, but it said it was for a f20. i assumed it is the same for the f22. i started it up and there was no noise. then when it warmed and idled it started to make this loud ticking noise. the car is MY06 with 53,xxx miles. i took it to honda and they replaced the tct under warranty. and it still makes the ticking noise. it only makes the ticking when i am at idle to 1500 rpm. if i am driving or rev beyond 2000 rpm it will stop ticking. any advise.
Old 01-21-2010, 05:47 PM
japhethwar's Avatar
Does not sound good, I would be pulling valve cover asap and checking valve clearance, or for some other damage. Something is definately not right. Also check the timing chain and guides could be an issue with the chain tension. It sort of sounds like the chain is sawing through the cover. Good luck
Old 01-21-2010, 06:37 PM
dammitjim's Avatar
Why were the valves bent?
2nd video = OMGWTFBBQ
Old 01-21-2010, 07:08 PM
ans2k's Avatar
No help?
Old 01-21-2010, 08:35 PM
rob-2's Avatar
Sounds like a diesel truck. I think you have done the valves wrong. Recheck your work and ensure proper clearances.
Old 01-21-2010, 09:10 PM
Avionics86's Avatar
Just a thought: did they pull the pin on the TCT? Not sure what it would sound like if they didn't.
Old 01-23-2010, 10:06 AM
ans2k's Avatar
Bump?!
Old 01-23-2010, 10:11 AM
dammitjim's Avatar
Originally Posted by ans2k,Jan 23 2010, 01:06 PM
Bump?!
How did the valves become bent?
Old 01-23-2010, 12:54 PM
ans2k's Avatar
I bought bad cams that weren't properly timed. So when I went to align them. All the marks lined up perfectly. Drove it for about 15 miles then the car just stopped on the freeway. Towed it back to a shop. Opened up the head and all the intake valves were bent.
Old 01-23-2010, 12:56 PM
ans2k's Avatar
If it is the valves. Wouldn't the sound increase as the rpm increased? Bc mine stop making that ticking sound after 2k rpm.
Quick Reply: Ticking idle
