ticking...
ticking...
I get a ticking sound after the car is warmed up and its idling.. It never happens on a cold motor.. and whenever i start it, the RPM's dip low and the oil light blinks for a fraction of a second then it goes back to normal idle.. the ticking noise will go away when i blip the throttle 90% of the time.. its really pissing me off.. any ideas?
Originally Posted by mattb1,May 3 2006, 09:23 PM
have you checked your oil level? low oil and your valves might be ticking. Valves ticking means they need an adjustment. what is the milage on the car?
What kind of rpm we talking about here? What is the idle rpm after warm up? What viscosity of oil are you running. Low rpm (<500) results in low oil pressure. Low viscosity oil can't generate adequate oil pressure at low rpm, especially when hot. Low oil pressure and hot oil = less oil getting to the upper part of the engine where all the valve parts are = more ticking. If it goes away when you blip the throttle (BTW, stop doing this. It only confuses the ECU and makes the rpm dip down low), then it's oil starvation.
I have an 00 and just got the 60K mile schedualed maintinance which is suppose to include a valve adjustment and I still have noticable ticking throughout the rev range...I dont understand
Originally Posted by darkfx,May 3 2006, 08:22 PM
mobil 1 10w-30 with a little castrol syntec 10w-30 (used to top off), with a PureOne filter.. its been there for about 2800 miles, 2 months..
Just because you got a valve adjustment done, doesn't mean it was done right. Use a stethoscope and listen.
