throttle "sticking" when engine hits VTEC
Old 02-16-2010, 08:10 AM
  #21
eric_reed_ii's Avatar
no. i tried that too. i just don't want him to bend the valves by lettin it bounce off the rev limiter too much.
Old 02-16-2010, 08:21 AM
  #22
Not Sure's Avatar
Is the ECU throwing any codes?
Old 02-16-2010, 08:24 AM
  #23
no. and i figured it would!
Old 02-16-2010, 08:40 AM
  #24
dammitjim's Avatar
Originally Posted by eric_reed_ii,Feb 15 2010, 10:55 AM
and it does the same thing in neutral.
I would have someone recreate this problem while stopped and watch the throttle under the hood when it happens. Does it actually get stuck or not?
Old 02-16-2010, 08:49 AM
  #25
Not Sure's Avatar
I think it only sticks after it hits VTEC. You can't hit VTEC while stopped in neutral.
Old 02-16-2010, 08:53 AM
  #26
yea...
Old 02-16-2010, 09:53 AM
  #27
fatjoe10's Avatar
Like Billman said, hook up a scanner and see what the TPS range is at WOT whenever the problems appears.
Old 02-16-2010, 09:56 AM
  #28
k thanks guys... i'll give it a try and post the results afterwards. again, thanks
-eric
Old 02-16-2010, 02:29 PM
  #29
Billman250's Avatar
Received 1,338 Likes on 810 Posts
You wont bend valves by hitting the limiter.
So if you are cruising say 3rd gear 5000 rpm....keep it to the floor. When you hit 6k, (without pushing the clutch pedal in) will the car continue to accelerate to redline on it's own? In other words, will the clutch hold and the car pull up to top speed in 3rd gear?
Your descriptions are not to exact detail...all details are needed...trust me I can help if I had them
This is by far the strangest issue I have heard of on the s2k so far. And I've seen many..
Old 02-16-2010, 05:21 PM
  #30
i've never tried to leave it in gear because i thought i would bend the valves if i let it bounce all day... i'll give it a try.
Quick Reply: throttle "sticking" when engine hits VTEC
