Throttle Position Sensors like hot cakes
Long story short. I am going to be on my 4rd TPS. I had the original one that failed. Went with my buddies extra TB, that TPS failed. Then I got the Omni or Izzy? TPS and now that is going out and I just replaced that maybe 4-5 months ago. Is there anything that would cause the TPS's to go out this frequently?
By the way, the car is tracked a lot.
Any ideas would be great.
I am not sure how the TPS is going out. It seems really strange, even if you track the car. Are you sure you are setting the TPS correctly? Just because the CEL says low voltage, doesn't mean its bad? It just means the 0% throttle voltage is lower than it should be. What is your 0% throttle voltage reading?
