Throttle position sensor failure & repair
Hi folks, got the error got P2138 and it showed as a throttle position sensor fault.
I cleared the code and the problem went away but returned intermittently. Sadly the error code is back and seems to be staying.
I think its probably due to the TPS sensor identified below which i checked with my parts dealer costs about 130 USD to purchase.
Does anyone know if this is the appropriate fix? Anything else I need to check or replace?
