Throttle Position Sensor
[QUOTE=N3DGB,Nov 21 2007, 06:51 AM] I could not find an exact replacement but the OMNI-Power Replacement TPS Sensor TPS-B-01 works just fine. The connecting plug sits lower requiring a clip on the wiring harness to be unsnapped. This clip can be snapped back in after plugging in the TPS. The voltage should read about .5 volts between the center pin and ground (the bottom pin). The tps can rotate to adjust for voltage. I checked the voltage on the original part and it was .12 volts. I had to perform the
WilloW (05-02-2017)
