throttle body
Old 06-30-2006, 02:15 PM
5thelement's Avatar
Default throttle body
has anyone here had problems with there throttle body not funtioning rigth i dont mean a messed up tps sensor or map there both fine. any high rpms or car feeling different
5thelement is offline
Old 06-30-2006, 03:27 PM
Slows2k's Avatar
What is your car doing?
How do you know the TPS and Map sensor are fine? You need to provide more details if you'd like some feedback.
Slows2k is offline
Old 06-30-2006, 04:14 PM
xviper's Avatar
Slow, I know a discount place where you can buy a crystal ball.
xviper is offline
Old 06-30-2006, 06:15 PM
Slows2k's Avatar
No Crystal balls, they are too unreliable. I'm using these from now on
Slows2k is offline
Old 07-01-2006, 12:37 PM
5thelement's Avatar
there new sensors and the problem im having was with the adjuster screw but i have played with that just wondering if anyone else with a thorttle body had a similar problem
Old 07-01-2006, 01:04 PM
vtec9's Avatar
a run-on sentence is a sentence without punctuation marks where they should be and as a result combining what should be many sentences into one long one which can be endless and although this is a run-on sentence with quite a few words it is far short of run-on sentences written by people with too much time on their hand
vtec9 is offline
Old 07-01-2006, 01:48 PM
ScottyBallistic's Avatar
Did you just replace the TPS or did you also calibrate it with a volt meter ( you cant just play with it ) . If it is not set correctly it can cause problems .
Did the problem start before of after you replaced the sensors ?
I would suggest picking up a factory Helms manual from E-bay or something ( about $40 for the book , the CD is a PITA) and follow the procedures . It will be way more helpful than what you are receiving here . It will not try to teach you grammar lessons
ScottyBallistic is offline
Old 07-03-2006, 06:48 AM
5thelement's Avatar
we did calibrate the tps we tried new sensors and the old ones still have idling problems i believe its the new throttle body. I came on here to get info all im getting is smart ass stuck up s2k owners being post whores except for vtec9 and twiztid thanks for trying to help
Old 07-03-2006, 07:01 AM
xviper's Avatar
[QUOTE=5thelement,Jul 3 2006, 08:48 AM] I came on here to get info all im getting is smart ass stuck up s2k owners being post whores except for vtec9 and twiztid
xviper is offline
Old 07-03-2006, 09:05 AM
GranPrix's Avatar
5thelement, we might come off a bit sarcastic, but that's b/c we get vague questions like these all the time, even your title is vague. And you still haven't said what the engine is doing. All you've said is that you are having idling problems, what kind of idling problems?
GranPrix is offline
Quick Reply: throttle body
