Thoughts on clutches
Old 07-23-2007, 05:56 PM
  #21
MaxGeek's Avatar
Don't get the Act kit if you want it to be light. I got it and it is heavy and the clutch comes back very fast.
Old 07-23-2007, 06:34 PM
  #22
S2KPUDDYDAD's Avatar
Originally Posted by BlownAP,Jul 22 2007, 12:35 PM
p.s. what Throw out bearing are you using with the spec? oem?
OEM is your only choice for the bearing there is no aftermarket available.
QUOTE:
mwilly00
Ok, dumb question but does the spec pressure always rotate? Will the engine rev more free with the clutch disengaged like it would with a light flywheel? Thats the only thing that would turn me off.
Thanks,
Matt
The pressure plate rotates with the flywheel, they are bolted together. The disc is the connection between the engine and the transmission. The disc is engaged and disengaged by pressing the clutch peddle in and out.
I bought mine used you will have to call or Email your respected Spec dealer to get an exact price quote.
This has been the best PP I have experienced in this car and for daily driving hands down IMO your best choice.
Used with OEM disc 30% better grip than stock used with an ACT or Spec type street disc 70% grip over stock.
Like ACT, Spec uses the same pressure plate in all stage clutch kits. The increase grip force comes from the design and friction material used on the disc. The pressure plate is a little stronger than stock that is why you have a 30% better grip with the OEM disc.
Old 07-24-2007, 08:22 AM
  #23
mwilly00's Avatar
S2KPUDDYDAD Posted on Jul 23 2007, 09:34 PM
Cool. Thanks.
Old 07-26-2007, 06:41 AM
  #24
LubedKoala's Avatar
That's what I wanted to know. Thanks!
So that leaves me with Exedy and Spec.
Any differences between the PP or discs of each brand?
Old 07-26-2007, 06:48 AM
  #25
LubedKoala's Avatar
Here's how transmissions, clutches, pressure plates work. FYI for anyone interested...
Clicky
JoeyBalls
01-24-2009 05:19 PM
08s2000CRbackinblack
74
10-29-2008 09:12 PM
Boostedtaco
06-15-2007 08:27 AM
smccurry
07-08-2005 03:29 PM
s-duces
Member S2000 Classifieds and For Sale
03-08-2004 08:20 AM
Quick Reply: Thoughts on clutches
