For those with the Comptech CAI
Good tip with the screw "gaskets". I had one of the screws come off after about a week. Not cool.
I called Comptech and told them they should add some lock/split washers in with the hardware kit to prevent this. They sent me an extra set of screws - free.
Don't know if they'll take my suggestion. You just have to take care not to add too much height to those screws since rubbing is still an issue.
-Hockey
-Hockey
ok i just installed mine today.. now the box seems like a pain to get in perfect but it mounted
on my 01, do you need to use that long bracket with the bend in it
i only have 2 bolts holding it down, but when i put the cover on the hook prop holder is kinda seen but i dont know if the prop is going to drop down and move over to fit
does it have to be perfect in the slit to work? i am going to grind the nubs down now... and see but that box was a bish to get in
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
One bracket has a 90 degree bend. That is the front mounting bracket. The long bracket with the slight bend is the fender bracket. My box fit perfectly with all three screws after I moved the wiring harness.
yea i kinda figured it out, i put the nipple part twoards the box and put the screw through... then the bend sticks into the box
i got it good where i can manage to get the prop into there but it takes a tad of effort
wheres teh cheapest place to get the tein hood dampers, thier site said 160
any help would be greatful im a new s2k er
also i keep getting a cel.. now i re did the vac lines a few times
anyone have a better pic of the air control unit upside down, i read the directions but both times i changed it up i keep getting it, though she drives fine
intake is so loud, its nice but its kinda meh... hahahah
Originally Posted by MaxGeek,May 24 2005, 10:09 PM
Hood dampers are like ~$130 in the sponsor/group buy secion
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
Originally Posted by billman250,May 25 2005, 10:34 AM
Wtih the hood dampers, can you still put the hood in the straight up position?
