Third gear grind
Third gear grind
I was driving my car yesterday and all of a sudden the third gear started to grind. It grinds bad. There was no gradual grind either, it just happened and now it wont go away.
The car is a MY00 with 12k so it doesnt get driven much but i do drive it hard sometimes. I have never misshifted and never overrevved it, which is why the grinding seems wierd to me.
I changed the oil yesterday to GM synchromesh and the grind is still there.
Please let me know if you guys have any ideas on what happened to my tranny and whether or not I need a new one. I didnt think this would happen with just 12k
Originally Posted by S2Gizzle,Nov 12 2005, 11:08 AM
I thought about the clutch fluid but kinda ruled it out because it only does it in one gear.
How much better is the Friction modified stuff?
Non friction modified has been found to not last long and its affects unproven. As for how much better the FM stuff is, again, you'll never know till you try. And again, a few bucks or BIG bucks. Yet another choice you must make.
ps. How is the 4 to 3 shift? Any grinding? Have you always "cut the corner" in the 2 to 3 shift? This is not a good habit and as the syncros wear from this kind of shifting style, continuing to do this may simply aggravate the situation. What I mean by this is the habit of going in a diagonal when moving the stick from 2 to 3. It is more of a distinct direction change than a diagonal ....................... move stick up, then to the right, then up into 3rd.
Originally Posted by S2Gizzle,Nov 12 2005, 03:36 PM
The 3rd to 4th shift is normal and very smooth
but the 4th to 3rd shift grinds just as much as the 2nd to 3rd shift
If it is the synchro, which im sure it is.....would I have to buy factory synchros or are there any stronger ones that can be used.
I was told that the ap2 transmissions have stronger synchros, but do those work in the ap1 transmissions?
thanks
Rovin
thanks
Rovin
