Think I blew the dif
I did a semi strong launch. Car made it up to about 40kmh.then grinding in the rear. All the gears seem fine but if I go over 3kmh the rear starts grinding. How can I go over to see what's broken? I'll probably end up going to a shop. I guess I'll look for a stronger different also.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
What fluid were you running ? It doesn't sound good though.
so i lifted the back up. both wheels turn ok. i started the car and got it up to 20kmh and there was no noise with the wheels off the ground.
in first gear it was fine. then i went to second gear and it eventually made a noise. then third no noise. hmmm I'll check fluid.
https://www.youtube.com/watch?v=umsI...ature=youtu.be
I'm starting to think it's not diff also, but I'll check it out at a shop soon. There was nothing on the diff drain plug in terms of particles or metal.
Lifted up it can go up to a a few speeds. But normally it just grinds.
0:17 the sound after shifting to 2nd, and 0:28 after going into third.
Do you have grinding whether the car is going straight ahead or turning one direction or the other?
