are these any good diff & trans oils
did anyone use these and are they any good or not
diff oil castrol syntrax aniversal
castrol saf-xj
castrol epx 80w90
trans oil castrol smx-s
grtz kristof
castrol saf-xj
castrol epx 80w90
grtz kristof
this i found and i found the oils on the site from castrol
http://www.opieoils.co.uk/p-739-castrol-sm...sion-fluid.aspx
http://www.opieoils.co.uk/p-744-castrol-sy...c-gear-oil.aspx
http://www.opieoils.co.uk/p-736-castrol-sa...-lubricant.aspx
If you are stuck with using a Castrol differential gear oil, I would recommend the 140 multi-grade GL5. The 90 multi-grade seems a little on the thin side to me. You can expect both of these to shear down a grade too, since they are multi-grade. Good luck!
