Thermostat & Switch Install
I just ordered my Spoon Thermostat, Thermoswitch, and Radiator Cap. I was trying to look up some install info, but there really isnt much avalible. I dont know if I am supposed to drain the radiator or not, the older posts just seem unclear. I went to Helm's site, and tried to find the famous Helm's manual everyone is talking about, but it wasnt quite that easy, I didnt know exactly what I was looking for, and the search came up with nothing on their site. Does anyone have a detailed install, pics would be most appreciated, and also, where the heck can I buy a Helm's manual for the S2000.
The only other thing I will have to learn how to do is change the radiator cap, I think I will have a honda service tech help me with that one.
i have these two items waiting to be installed as well. from what i've heard in past threads, it is not an easy task. i believe it is necessary to drain the radiator. hopefully someone who has done this in the past will shed some light.
If you do a search on 'Mugen thermostat install' you'll find several threads detailing how to do it. The instructions will be the same for any make of t-stat or fan switch.
The thermostat is not easy to get to, and you should drain the coolant first. The fan switch is very simple, but you'll need a 24mm deep socket for your torque wrench. The torque figures are 17lb.-ft for the fan switch, and 8.7lb.-ft for the 2 bolts on the thermostat housing. You may need a wobble head wrench to get to the bolts on the thermostat housing.
I will try another search, and I found the manual I was looking for too. I have just about every tool in existance, so there wont be any problems getting to the bolts... I was just hoping I dont have to drain the coolant to do this job. If the system is not empty of coolant, when I remove the thermostat, will the coolant come with it?
Here is xviper's DIY thread on coolant changes.
https://www.s2ki.com/forums/showthread.php?...&threadid=86811
