Is there a way to clean out my ap2 rear tails?
it's getting worse with every carwash! help i think the seal is bad behind it, but if i were to even fix it, i'd like to clean it out first.
i'm guessing the only real way would be to bake it open?? it doesn't come apart right?
I had this problem, i fixed it by taking the light apart and rinsing the inside with windex. Then i poured out as much as i could and then baked it @ 200F for 15 minutes. (don't put the light directly on the oven rack.
worked great and my lights look new again!
yeah bake it to get rid of the moisture, I put mine on a wood cutting board , using 200-220 degrees is safe, fahrenheit degrees that is.
