Is there easier way to replace crank angle sensor?
Old 06-14-2021, 03:03 AM
Slowcrash_101's Avatar
Originally Posted by RolanTHUNDER
Can this sensor prevent the car from starting. I think that's my issue.
Not the clutch interlock switch?
Old 06-14-2021, 05:11 AM
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Correct me if I'm wrong, but I'm assuming it'd be easy to rule out one of those two hypothesis. With a bad crank position sensor, wouldn't you get crank but no start, where with an issue with clutch interlock you'd get no crank at all?
Crank being defined as push start button, and engine goes roundy round, tryin to start, but never does. No crank being push button and nuthin happens at all.
Old 06-14-2021, 11:41 AM
RolanTHUNDER's Avatar
I don't got that nonsense
I was referring to the CKP. Can that cause no start or more accurately, failed start? Just as it attempts to start from cranking it stumbles out and the process repeats...?
Old 06-14-2021, 11:43 AM
Your description of each is correct.
Daren 83
07-22-2011 12:34 AM
tmkpres
06-04-2011 03:09 AM
Cycloneranga
09-29-2006 09:05 AM
asdfg123hk
12-08-2005 07:27 PM
deebo
04-28-2005 11:53 PM
Quick Reply: Is there easier way to replace crank angle sensor?
