Is there a DIY for Fuel Filter Change
I'm looking to change my fuel filter, and all of the DIY's posted keep my car running smooth, thanks for that.
We have no fuel filter, just a fuel "sock" and it's on the bottom of the fuel pump assembly, which is inside the fuel tank. It's not an easy bit of maintenance nor is it indicated in the service manual. Unless you suspect you have been using dirty fuel, I guess Honda considers the sock to be good for life. If you feel you really must change it, Honda does sell the sock kit and you can go to the supercharger install manual and find the part that covers getting the fuel pump out. Once you have it out, it should be pretty straight forward to figure out how to swap the sock. I have noticed, however, even after only about 20K miles, the original fuel sock is pretty discolored. This doesn't necessarily means it's had it.
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
Member
It is a service item on a UK car, cant remember what mileage / interval but its quite high.
Here's how I did mine!
https://www.s2ki.com/forums/index.ph...ic=383496&st=0
MB
MB
