test pipe woo's
test pipe woo's
I just installed a test pipe last night.....Pulls noticably harder then befor.....got a CEL(i got the o2 sim to fix this) i am wondering if it is supposed to sounds rattly or if that is something loose...i havent got back under the car to check it out yet but i think it is somethign loose........anyone else with a test pipe have these issues?
if your car is NA, a test pipe wont give you no more than 2 hp...and if your not running an aftermarket ECU, u should reset the stock ECU to let it learn the new setup...either way you wont have a noticabe gain from it.
Mine rattles. I can only hear it with the windows up and music off. I searched to see if it was normal and read it was normal. I have stock exhaust and I felt no gains. Mine felt more like I lost top end. If I don't go FI soon, I'm tossing it.
Chris E.
Chris E.
I don't think mine is an exhaust leak. The best way to describe the sound is that it sounds hollow. My exhaust tone has not changed. Light throttle sounds deeper but WOT sounds stock.
Gernby, what type of exhaust do you have?
