TEST PIPE w/o CEL on?
Im looking at getting the t1r test pipe for my s2k, but im concerned about the CEL always being on. i dont mind looking at it but im worried that if a real problem occurs i wont know it, because the light will be on anyways. has anyone else found this a problem, or maybe found a way to trick the computer? any info would be great. thanks.
no there is a much easier way, go to autozone and buy a set of 18MM spark plug defoulers, it basically pushes the 02 sensor back out of the exhaust flow causing no cel, there was a pic somewhere.
Or just get this test pipe. That's what I did.
https://www.s2ki.com/forums/index.php?showtopic=321104
can you but the stock heat shield on this item so it looks stock? the t1r will fit the stock heat shield and im trying to make it look as close to stock as possible.
