Test pipe leAk help (BERK TP)
#22
http://i73.photobucket.com/albums/i2...psxaebhjbc.jpg
If you look at the two pipes, the angles and geometry of the pipes are slightly different. I think this maybe contributing to the miss-fit, as much as flange issues.
Anybody have an older 63mm TP? I'm wondering if they look the same.
#23
Mine came from Berk directly. It's a 63mm test-pipe. Need to find a way to seal this.
Thank you for your contribution. It seems like there is an issue with Berks test pipe fitment. What size is yours?
I bought mine last year around August/September. Hope Berk see's this thread and will do some action.
Originally Posted by xpressive' timestamp='1461688543' post='23948883
I have the same issue. Brand new TP from Berk in March and the spring bolts cinch all the way down and there is still a leak..
#24
Site Moderator
Maybe a silly question but have you tried using you old donut gasket and bolts? Are all the new parts OEM Honda or aftermarket? Maybe something is just a little different and it is not sealing up right?
#25
Yes I tried my original gasket and hardware first and when that didn't work I tried brand new oem gasket and hardware. Same leak. Same problem.
#27
Was this ever resolved? I'm in the same scenario as you mentioned here except I have a Berk 63.5mm HFC, but the rest the same.
Everything is new: gaskets, bolts, springs etc.
I called Berk last week and they told me their tech person is out until end of next week.
#29
Nope... they refuse the respond to any emails. I have sent several. I still have a brand new Berk test pipe sitting in my garage because of this.
