Test Pipe Installed w/ sim
i have a MY06. installed invidia test pipe and did the spark plug antifouler sim trick. the first pair i did i left the fouler that threads to the test pipe alone then i drilled the second one out to 1/2 in. i threw a cel in 2 cycles less than 50 miles. reset comp threw another cel in 2 cycles. then on the 2nd attempt i drilled the second one out to 7/16 but not all the way through just enough for the tip of the o2 to fit. threw a cel in 4 cycles and about 50 miles. so im not sure what to do. maybe add a third anit fouler to it? i was thinking of maybe drilling a small hole through one side of the first anti fouler so the gases could vent. any ideas would be greatly appreciated.
has anyone had sucess with the comptech part? im sure it works cause all of comptechs stuff is the shit. can you order from comptechs website? i have placed a order with them before and they never charged my card or sent me anything. anyone order from there site before?
Nope. It plugs in, that it. I used an ECG 5 wire sim and a 13ohm 10 watt resistor to fool the 02 heater circuit before. The comptech piece does the same all in 1 box. Both the Comptech and the ECG never failed.
I bought mine used a year ago, before Comptech had decided to sell them to the public. The simulators where on Comptech's website the last time I looked, but that may have changed. S2ki has several vendors that are Comptech dealers I'm sure 1 of them could tell you.
