Test pipe, cel, and electronic devices...the definative answer?
Old 05-12-2003 | 06:09 AM
  #31
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by speeeding
[B]So far the CEL hasn't come on after 30 miles of driving.
Old 05-12-2003 | 05:35 PM
  #32
cdelena's Avatar
For any of you that pulled the secondary O2 sensor.. I am in the market for one. PM me with a reasonable price.
Old 05-13-2003 | 02:52 PM
  #33
speeeding's Avatar
Here is the dyno result:
The red line is with the test pipe and the blue line is the cat.
Max. power w/ cat: 196.9 and 130.9lb.ft torque.
Max. power w/ test pipe: 195.3 and 132.2 lb.ft torque.
I lost 1.6 hp but gained 1.3 lb.ft of torque.
The graph shows a significant loss of power and torque before VTEC.
So here it is.
So far, I've put 96.3 miles on the test pipe and the CEL has not come on yet.
Old 05-13-2003 | 03:27 PM
  #34
Gernby's Avatar
Former Sponsor
That is pretty disappointing. Did you monitor coolant temps and reset your ECU before each run? I really think that comparative runs for mods need to have unlearned ECUs, since the learning was all done with the pre-mod setup.
Old 05-13-2003 | 03:56 PM
  #35
speeeding's Avatar
I didn't reset the ECU with each run. Do you think that might help?
Old 05-14-2003 | 05:51 AM
  #36
Gernby's Avatar
Former Sponsor
[B]I didn't reset the ECU with each run.
Old 05-14-2003 | 09:31 AM
  #37
Gernby's Avatar
Former Sponsor
Unfortunately, everyone that has removed the cat, and is using an O2 simulator, is probably still using their Secondary sensor. The simulator only prevents the ECU from generating a CEL based on the output, but the sensor itself is still needed to prevent the ECU from generating a CEL based on the power load and heater load.
Old 05-14-2003 | 09:35 AM
  #38
cdelena's Avatar
Thanks for the tip Harry.. you are right, it is all about price. Mine is fine until is gets jostled from a big bump, and then it throws a code for high or low voltage. It is just a pain to pull out the PC to turn it off, since I have gotten to the point that I won't pull the fuses.. learning the fuel trim takes too long for me.. the idle and throttle response sucks until then.
Old 05-14-2003 | 06:02 PM
  #39
speeeding's Avatar
I've gone through nearly a whole tank of gas without the CEL. Is this normal?
Old 05-15-2003 | 05:24 AM
  #40
Gernby's Avatar
Former Sponsor
[B]I've gone through nearly a whole tank of gas without the CEL.
Quick Reply: Test pipe, cel, and electronic devices...the definative answer?
