Test Pipe
Test Pipe
Ok, so I'm a little annoyed with my test pipe (Invidia 60MM) right now. It rattles when I'm in low RPM..like 2Kish. When I first installed the TP a couple weeks ago it was fine. Then a few days later I started hearing the rattle. When I first put the TP in I torqued the bolts all the way down on those 2 spring bolts (Sorry, dont know the technical name for them). The rattling got so bad I needed to do something about it so I loosened the spring bolts out about half way. It got a little better but the rattle is still there. Does anyone else have this problem? Do I have to live with it if I keep the TP in? Any suggestions on what I can do? I am assuming the TP is hitting the heat shield that's above it...
Thank you!
Lu-Dawg
Thank you!
Lu-Dawg
I'll do that for sure. I ran a search and people also suggested taking out TP and re-installing making sure it does not hit the heat shield. I thought it only fit one way but I'm to a point where I'll try anything. This seems to be a comon problem with test pipes. Thanks for the tip
Lu-Dawg
Lu-Dawg
