Temperature gauge going up and then down
Old 03-09-2005, 05:54 AM
DVSwetwilly's Avatar
Default Temperature gauge going up and then down
well this happen like 30mins ago.. i start the car like normal let it warm up until 3 bars... but gas then took off... when i left the gas station it was normal so about a 1mile down i see my temperature rise and i was like oh shit wtf is going on....so i pull over 2 see if i have a leak or anything i don't see any thing... so let her rest for like a good 5mins started the car and went on my way....again it went up and then it started to go down back 2 normal... i was like wtf is going can someone help me please!!!!
Old 03-09-2005, 06:21 AM
xviper's Avatar
So you are saying it went to 4 bars, then back down?
Old 03-09-2005, 06:23 AM
it went 4,5,6 bars then go down
Old 03-09-2005, 07:02 AM
xviper's Avatar
There might be something wrong with your temp sender, gauge or wiring. Did you notice that when your bars went up that high, how long a time frame did this happen? Coolant temp can't go that hot and cool down in a short time frame. And did the rad fan come on? For sure, if 4 bars was "real", the rad fan would have kicked in. I would think that it is highly unlikely that the actual temp of the coolant got to 5 or 6 bars without some serious boil over.
However, the temp sensor is near the back of the engine close to cylinder #4 - you know, that infamous #4 cylinder failure? I don't want to alarm you but do check to make sure that #4 is OK and there is no weird "hot spot" at that location for some reason. A quick check of the spark plug and a look down the plug hole could tell you if things are normal. Did you ever get the spark plug recall done?
Old 03-09-2005, 07:09 AM
i never got a spark plug recall done i change the spark plug with NGK iridium
Old 03-09-2005, 07:10 AM
when i look down #4 what am i looking for
Old 03-09-2005, 07:26 AM
xviper's Avatar
First, don't get too concerned about the #4 thing. You still haven't answered my question about how quickly the bars go up and down and the rad fan thing. This will give a clue as to whether or not it's the gauge.
As for the spark plugs, did you increase the torque as recommended in the recall? The old torque was deemed inadequate and the plugs were backing out. This was feared to have been responsible for some of the engine grenades although Honda will not say this conclusively.
If you look down the plug hole, you should be comparing what you see with the other cylinders. If #4 looks about the same as the others and the plugs all look about the same as each other, then chances are this is not of immediate concern. You don't want to see a different coloration of the piston top or any debris down there. You don't want to see the plug tip damaged in any way. You don't want to see the white porcelain part of the plug looking overly "baked" compared to the other plugs (brownish tingue near the metal part).
Old 03-09-2005, 07:33 AM
well the bars would go down rather quickly like it will hold at 5bar then go down... rad fan thing coming didn't pay attention if it did or not
Old 03-09-2005, 08:42 AM
xviper's Avatar
OK, we're just going around in circles here. Please indicate what kind of TIME FRAME when you say "quickly". Are we talking seconds or minutes? I'm trying to help you but you're not giving me the answers I need.
Old 03-09-2005, 08:58 AM
sorry about this round about its in seconds
really quick seconds.. like when it would hit the 5th bar then bang it goes down i hope that helps
Quick Reply: Temperature gauge going up and then down
