Temp. knob light going in/out (loose cable/bulb?)
Since installing my Modifry dash bracket, I've been having intermittant problems with the temperature control knob. The light would go on/off .
If I lightly hit my dash from the side it (temp control lights) would go back on or off. Is there a bulb thats directly behind this knob? I don't quite know how to take the temp control unit out, but is there an easier method to correct this problem?
thanks!
thanks!
I just installed one yesterday also. It sounds like you might have a loose connection. Look in the FAQ DIY for instructions on dash light replacement...you will see which connector you might need to snap back into place.
Grip Hrd
11-30-2013 05:32 PM
ryanswhites2k
07-05-2011 04:48 PM
