TDC sensor location
TDC sensor location
I was having cel code 1366 so switched TDC sensors locations (swapped positions). Now code is 1362 and 1367. Which sensor is Honda referring to as #1 sensor vs #2 sensor. Thanks for any help. Also, car is Vortech supercharged and have already soldered the timing controller wires at the kick panel. Thanks again.
You mean the crank angle sensor?
That one is mounted on the cam chain case pointed at the crank by the crank pulley
Or the cam angle sensors?
The two sensors at the back of the valve cover.
unowned
04-11-2021 08:19 AM
