TDC camshaft sensor position B
Luckily when I was pulling in to park at my house. The cel came on. It was late so I wasnt able to go to autozone to get the code, will do that first thing tomorrow.
Code is P1366 TCD
I did notice a noise in the engine which sounds like air leaking or escaping from around the throttle body.
I took a video of it and its taking a LOONNNGGG ass time to upload. Will edit when it gets uploaded.
http://www.youtube.com/watch?v=XgTdsOdTUeg
2000 AP1 with K&N intake, everything else is stock.
Thanks!
Code is P1366 TCD
Thanks!
Are my coil pack suppose to look like that?
the #2/3 doesnt have any rubber boot at the end. I check the 1 and 4 and they both do.
Replaced them back and now car wont start.
As for the air leaking sound. i just switched the hoses in the air valve and it went away.
what happened to those coilpacks? Did the rubber boot stay down on the plug??? Is it my imagination or are #2 and 3 a different color?
Yeah they are. #2 has a taint of brown and #3 is somewhat cleaner. I checked the inside and there was none to be found.
Installed two new oem 04-05 coil pack but still won't start.
Also, they fit in perfectly so I don't think the rubber is left inside.
Still haven't tried changing the spark plugs.
Also can a tdc cause an engine not to start?
Start with a check on the plugs, if ok try en ECU reset to see if it will start. You can try swapping the sensors on the valve cover and see if the code changes from 2 to 1 as well.
I was throwing a P1399 and the car still started and ran, just ran like sh@t. You could probably stand to do a plug change as well as those 2 coilpacks. Maybe to start just pull the plugs and see what condition they are in. I'll do a little looking around for you and see if I can come up with some ideas for you.
See stupid me cleared the cel and now it might take awhile for it to comeback again.
I checked the sensors and they both have about 2.2-2.3 ohms (used an analog meter) and checked the pins that connect to the sensor and they both have 9ohms, I was told that the pins should have 0 ohms/no resistance when checked.
Quick update. The car IS running now. I used the new coil packs and switched the tdc sensor. Pretty sure cel will come back.
I found a piece of tiny metal suck on one of the sensor wiped it off and switched them. Maybe that's what was wrong blocking the circuit or something.
