Is this TCT noise, or normal
Sounds normal
Did the sound get louder after the valve adjustment? If they were too tight before they'll be a bit nosier when set to the loose end of the spec (which is recommended as they tighten in use).
-- Chuck
-- Chuck
I thought the exact same thing when fully warmed up since I bought it 10 months ago. A Honda tech from this site did the valve adj, new TCT, plugs, belt, and all fluids. Sounds the same after maint was done.
duhwinning
10-14-2015 09:26 AM
