Tapping noise when cold?
Just wondering if anyone else hears a regular (fast) tapping noise when our cars are cold for about the first 5-10 mins into a drive? but dissapears once the car is warm? Is it somthing I should be worried about?
Thank you
Thank you
Originally Posted by Slows2k,Nov 21 2005, 05:09 AM
Possible timing chain tensioner problem if the noise goes away when it's warmed up.
If it's the tensioner, the noise you are hearing is from the timing chain not having the proper tension applied to it. I'd worry about it.
I also have replaced about 5 tensioners in the last year. It's a fairly common problem.
No, it's not a regular maintenance item. I've never heard a replacement tensioner make the same noise the original did.
It would also get expensive replaceing them all the time. (they run $125 just for the part)
I've been driving my car for quite a while before I found a thread that addressed my problem was the tensioner.. I don't think theres any long term affects.. however you probably would want to replace it soon before anything DOES happen .
I had the tapping AND the starter after-run sound.. which is what peaked my worry ... After replacing the tensioner it definitely solved my problem.. starts without a sound jus like when it was new
