Takata harness w/o Roll cage. Can it be done? Has Anyone done it?
Before people explain to me the pros/cons of no rollcage and harness (I've read the posts, did the research, etc..), I'm curious to know if it is possible or not. And, if it is possible, how was it done, and do they have any pictures? I've read posts where people have posted suggestions on how it could be done and have seen pictures with the harness (but not attached). I'm curious if this is possible since I'm yet to see it. Thanks!
There is a reason the seat belt is positioned how it is... If it was positioned at any other angle it could break something of yours if you were in a wreck. That being said you would have to have the harness positioned correctly if you did not have a roll cage.
bryan
bryan
You could possiblly attach the harness straps to the factory roll hoops, though you'd have to cut the plastic to go around the metal bar itself. Then again, unless you're head doesn't go above the stock hoops, you probably aren't that concerned about the safety aspects of the setup anyway so attach them however you can work it ..
