tail lights not working
when I turn my lights on, my head lights work, but my tail lights dont now. my blinkers and brake lights still work. I checked some of the fuses and they are good.
has anyone else had this issue, and how did you fix it?
thanks
thanks
check the light bulbs.
if you have a test light, check for power going to the bulbs.
double check the fusses. i've come across fuses that looked good but were actually bad. replace with another fuse of the same amperage and see if that fixes it.
I just noticed that my guages dont get lit up anymore when I turn my lights on either. I am really thinking this has to be a fuse anyone know what exact fuse controls this?
my advice is. unless you have a power probe test light to test all the fuses electriclly not by looks then go to a shop and tell them to check it for you and that you want all the blown fuses replaced.
make sure you watch them do it. cuz they will try to rip you off and replace fuses that arent blown.
where are you loocated. i work at a shop if your in the area i can help you out/
Y0N1P8T5R1F5A4T
01-06-2014 11:03 AM
