Tail Lights
Tail Lights
I was informed that my right rear brake light was not working. OK, I'll just replace the bulb. Replaced the bulb (the one with two filaments). Rechecked the brake lights, no good. Must be a bad replacement bulb. Replaced with another new bulb. Still no good. Must be the fuse. Checked the fuse, it was good. Must be the bulb socket, checked that; it was good. The left rear and center brake lights works when the brakes are applied. All three works when the park light is turned on. Checked the wiring harness with a test light...the park light works and the brake light doesn't. Do I have an open wire somewhere? Any ideas? Will the dealer fix this under warranty?
gray.s2k
06-15-2018 01:54 PM
rsStewie
04-29-2016 03:07 AM
