Tach / Redline Question
Originally Posted by sahtt,Dec 13 2005, 10:02 AM
There is no mileage recommendation for that because it will damage your car, or at least accelerate diff/tranny/clutch wear regardless of miles. If you are realistic about what you are doing to your drivetrain, then go for it, but eventually it will come back to bite you. Launching every once in a while isn't going to kill the car, but I'd avoid doing it on a daily/weekly basis for sure.
Originally Posted by xviper,Dec 13 2005, 10:02 AM
The degree that the "monster" presents itself is directly proportional to the rate and depth of throttle pedal operation. Applying WOT (wide open throttle) quickly will give you a much more pronounced "monster" and a more dramatic VTEC engagement.
If you are going up to redline gradually and moderately, you are missing the point.
Regarding the "sound" when the VTEC engages...it is relatively quiet. I am sure it gets louder with I/H/E. My K20A2 with I/RH/E sounds down-right MEAN when the VTEC engages.
Originally Posted by SIIK2NR,Dec 13 2005, 10:16 AM
@8K the redline will flash.....after the 3rd flash you will hit fuel cut off..
If you can manage to shift after a couple of flashes your golden. If you wait too long you will find yourself jerking vigorously due to the cut off.
Most of the time I just shift at redline but on a few occasions I've let it blink.
I don't know how many times it flashed...maybe only once. It caught me off-guard though.
